Gas guage/Instrument cluster
  • blacksport325
    • 231
    So I've searched the many threads on guages, however I couldn't come to a conclusion. The only gauges that work are temp and speedometer, I could care less if tachometer works, shifting using the engine sound isn't hard, however I really need my gas gauge to work, it is constantly stuck on full, I took the cluster out, and the gas guage has a resistance when i move the needle manually unlike the other needles. Could this be a bad ground or the gas sensor going bad?
  • blacksport325
    • 231
    bump, i'll be taking the cluster out today so i'm going to try and figure out where the ground is located.
    • george graves
      • 20003
      Try tightening the brass nut(s) on the back of the cluster. Should fix your fuel gauge.
      Originally posted by Matt-B
      • blacksport325
        • 231
        Thanks, I will check that out today, let you know if it works.
        • blacksport325
          • 231
          This worked, thanks! It sits just above half way now so I will see if that's correct, It's hard to keep track of how much gas i've used or put in recently, Is there a way to see into the fuel tank?
          • george graves
            • 20003
            Yes, remove the rear seat. That's where the sender's drop into the tank.
            If it was me, I'd just fill it up and see how it is.
            • blacksport325
              • 231
              I would but the tag just expired :down: Should have it back on the road in a week so i'll find out how accurate it is then, thanks again.
