Tach isn't smooth.
  • ryan_george
    • Mar 2004
    • 331
    Tach isn't smooth.
    I've just replaced my entire instrument cluster with the one from the 325i, in preparation for the engine swap.
    Put it in, and the tach/mpg weren't working. So I assumed the SI board. Swapped in the other one from the eta (working 100% fine), and bam! I have action.
    Now there is one issue with the tach and mpg gauge. They don't move smoothly. When accelerating they just jerk up/down, but do get to the correct rpm. I tried moving them by hand and I can't feel any abnormal resistance.
    Is the tach just about to die?
    Also, possibly related, my speedometer isn't reading very accuratly. I haven't had someone pace me yet, but it seems like it's under-reading my speed. Maybe it will fix itself once the engine goes in.
  • BavarianBimmer
    • 951
    Check ground plugs
    btw my tach has the same probs never found the issue
    1989 E30 318iS_______________________________1989 E30 325iC M-Technic I
    1997 E36 328iT
    1990 E30 325iT 24v SOLD
    1989 E30 325i 2.7i M-Technic II SOLD
    • 325Projectz
      • Jan 2005
      • 1956
      That SI board might be bad also, try to solder some new batteries to it.
      91 m3
      • Jand3rson
        • 37587
        Don't some SI boards have batteries that you can just pop in and pop out?
        • ryan_george
          • Mar 2004
          • 331
          My SI board was working absolutly fine with the other instrument cluster. Also, I noticed that the batteries on that board were short, 3v batteries. I thought they would have been standard AA 1.2v.
          • BavarianBimmer
            • 951
            EM and LM model style they changed in 1986 I tought
            1.2v are the reds and the small were Sanyo in 1986 and up
            1997 E36 328iT
