Throwout Bearing - Plastic or Metal?
  • mike87
    • 300
    hi all,
    just got the pressure plate and old clutch out of the car. my question is, the new throwout bearing in the sachs clutch replacement kit has a plastic assembly that goes over the transmission input shaft, whereas the old throwout bearing was all metal. should i opt for an all-metal bearing or is the new partially-plastic throwout bearing ok to use?
    thanks in advance!
    This bearing should be fine. The housing isn't under much load.
    • u3b3rg33k
      • Jan 2010
      • 2452
      Mine's plastic, 28,000 miles on it and no problems yet. Plastic won't rust and get stuck to stuff either.
      Ich gehöre nicht zur Baader-Meinhof Gruppe
      Originally posted by Top Gear
      Just imagine waking up and remembering you're Mexican.
      Every time you buy a car with DSC/ESC, Jesus kills a baby seal. With a kitten.
