where oh where
  • gokepsgo
    • Jun 2010
    • 202
    where oh where
    Do I find valve seals? I have an eta and one of the spark plug holes is leaking oil. Any ideas to what it could be or where I can get the parts?
  • gokepsgo
    • Jun 2010
    • 202
    Morning bump. Doin timing belt this weekend and really wanna get these done at the same time. Anybody?
    • whodwho
      • Jun 2008
      • 1547
      Doing valve seals is not really going to be an option with the head on, they also don't leak out the spark plug holes.
      Oil leak is most likely from the VC gasket - replace the valve cover gasket and home plates(shaft end plugs) and adjust the valves while your in there.
      You should also consider doing the water pump while you have all the front apart.
      My M20 Frankenbuild(s)
      4 Sale - Fully Built TurnKey Megasquirt Plug and Play EMS
      • gokepsgo
        • Jun 2010
        • 202
        Yeah I'm actually doing the water pump, thermo, timing belt, adjusting the valves, and replacing the vd gasket. I just wanna make sure this will solve the problem while I already have the motor apart. I may do the head gasket too idk how much more work it will be though. Does this sound right to anyone else?
        • gokepsgo
          • Jun 2010
          • 202
          Oh yeah and the hole isn't leaking on the motor or anything just on the tip of the plug like a tiny puddle.
