M Coupe / Roadster SSK part #'s
  • M42Technik
    • 9781
    Okay well I plan to finally do my short shift kit, and after all the different shifters I could choose from I decided on the M roadster shifter since the Z4 is way too low and others say the Z3 shifter is a bit smoother and low, and the M coupe being even lower, that would seem the best one to choose.
    Anyways, I need to know what parts I'll need for the whole procedure and the part numbers. The shifter, bushings, etc...thanks for the help in advance!
    And there isn't a difference between the SSK for the coupe and roadster, is there?
    Reminiscing...
  • Schnell 318
    • 567
    i personally love my z4 lever, the throws are just right and the hight is perfect. if you are worried about the hight just get a shift knob that attaches with set screws, so you can change its height
    • M42Technik
      • 9781
      Nah I'd rather just get that shifter. I just need to know the parts and part numbers needed...
      Reminiscing...
      • postmaster
        • 93
        Z3
        4x 25 11 1 220 439 shim $0.30 each
        1x 25 11 1 220 600 Shift Bushing - $4.00
        1x 25 11 1 220 832 Shift Lever Bushing $6.45
        2x 25 11 1 220 379 Clips $0.50
        1x 25 11 1 434 148 Shift lever - $43.81
        1x 25-11-1-220-600 Nylon ball joint cup
        Z4
        1x . . . 25 11 7 507 964 - Z4 2.5l Shift Lever $43.81
        4x . . . 25 11 1 220 439 - Spacer Rings
        1x . . . 25 11 1 220 832 - Rubber Bearing sleeve
        2x . . . 25 11 1 220 379 - Circlips $0.50 (one extra)
        1x . . . 25 11 1 220 600 - Shift Bushing - $4.00
        *EDIT* Carrier Bushings added
        M Roadster
        M Roadster Shift Lever (# 25-11-2-228-384) [required] -$52.25
        Nylon ball joint cup (# 25-11-1-220-600) $14.87
        Washers (2) (# 25-11-1-220-439) $0.47
        Circlip (# 25-11-1-220-379) $0.68
        Carrier Bushing (# 25-11-1-221-822 $6.98
        • M42Technik
          • 9781
          Thanks for all of the parts and numbers for the shifters! Is that all that is needed for the change for the M roadster one though? It seems like there's more from the Z3 and Z4 and not the Roadster...
          *EDIT* Thanks for the update!
          Reminiscing...
          • Super Eta
            • 1884
            That cheap! :shock:
            I think i will scrape some cash up for this.
            • M42Technik
              • 9781
              One more thing. How do you install it? Is it easy to do? Thanks again for the numbers I need!
              Reminiscing...
              • Bryson
                • 1490
                The M roadster shifter is super fuckin short. It's real notchy with the m20 trannies, no experience with an m42. The 2.8L Z3 lever is by far my favorite, the 1.8 is almost like stock and the 2.8 is still smooth and not too low, but the MZ3 is over doing it. Plus it sits much lower than the factory one, not ideal.
                I have the M roadster lever in my car, and my brother had both the 1.8L Z3 and the 2.8L Z3 shifters, the 2.8 owns. It's a perfect shift, no two stage bullshit, like I get with my M roadster one.
                Also, the M roadster lever will sit almost just as low as the Z4 one.
                anyway, that's my .02
                • M42Technik
                  • 9781
                  That I did not know! Well I think that this one will be fine, I can live with it. I can always switch if need be. But how the hell does it go in?
                  Reminiscing...
