UPDATE 14/19/10
I have posted this on R3V want optinins from you guys as well.
As the title states I am thinking of rebuilding the M42.
Reason: Well over the weekend while I was looking inside her, I noticed a water leek from an odd spot (on the air conditioner compressor). Anyways upon further inspection it seems to be coming from the head gasket . It’s a very small leek, but one none the less.
So if I am going to replace the head gasket I might as well do a performance rebuild.
Experience: Well non this will be my first ever engine rebuild I am confident, in my skills and hope I have read enough to do a good job. This is also part of the reason I am posting here. I have devised a list of parts I need and the machine work I will get done. I know what the prices are for the parts and was wondering if anyone could give estimates on the machine work required that I have listed.
Goals: Well I would like keep the price under $5000 and hopefully achieve 180hp without any real bottom end modifications beside 360Degree Thrust Bearings and oversized pistons, focusing more on the head.
Anyways here is the list
Metric Mechanic
-Rod Bearings $60
-Main Bearing 360Degree Thrust $120
Total From Metric Mechanic = $180
Vac Motorsport
-Titanium Valve Retainers $289.95
-Hardened Valve Locks $71.20
-1mm Over Sized Stainless Steel Valves $479.95
-Duel High Performance Valve Springs $447.95
-Vac 269/269 Cams $949.95
-ARP Main Stud Kit $149.95
Total Option 1 From Vac Motorsport = $2334.95
Possable Option 2
-Stage 2 Cylinder Head $1399.95
Total Option 2 From Vac Motorsport = $2499.95
Pelican Parts
-Head Gasket Set $106.75
-Hydraulic Lifters $276
-Chain Tensioner $39.75
-Timing Chain $56.25
-E28 Motor Mounts $44
-Bottom End Gasket Set $65.50
-Oil Pressure Relief Valve $10.75
-Cam Sprocket x2 $108.00
-Crank Shaft Sprocket $67.25
-Deflection Wheel Sprocket $145.00
Total From Pelican Parts = $909.35
Bav Auto
-Oversized Pistons $439.95
Total From Bav Auto = $439.95
Total Option 1 Cost of Parts = $3864.25
Total Option 1 Cost of Parts AUD = $4293.61
Total Option 2 Cost of Parts = $4029.25
Total Option 2 Cost of Parts AUD = $4476.95
So this dose not leave me with much room for machine work so I am just going to list the things I want done and if anyone can put an estimate to the cost that would be good. Then I can review my parts and see where I could save a bit.
Block
-Crank Shaft Alignment Honing
-Decking Surface
-Hone Cylinders
Head
-Deck Surface
-Increase port and valve seal size to suit new valves
Crank
-Probable fix spun main bearing journal
-Chrome journals
There will also be inspection for cracks and repairs but that is an unforeseen problem which I can not list and will just have to see what happens there.
So that is what I have come up with so far. The car has done 190,000km so I am hope there will not be any major problems but you never know.
As you may have already noticed I have not really done much with the timing components, when I last looking at the cam gears and chain it looked in very good condition, so I am hoping that the guides will be in good condition. But if there any evidence of problems then they will be replaced.
I would like peoples comments and any help with what I have listed, also an estimate on the cost of the machine work would be a great help.
Cheers Massimo
PS I should add i am going to try my hand at replicating the Metric Mechanic Pulse Chamber.
Metric Mechanic
-Rod Bearings $60
Vac Motorsport
Possable Option 2
Pelican Parts
Bav Auto
Block
-Decking Surface
-Hone Cylinders
Head
-Deck Surface
Crank
-Chrome journals
Cheers Massimo
