odometer troubles (not the gears)
  • mkcman17
    • Jul 2010
    • 8240
    replaced all 3 gears in my VDO and still won't turn when driving. i tested them by hand and they work fine, so i'm guessing it's something to do with the coil magnet motor? oh, also, will a VDO odo work in a moto car? the speedo does work when i plug the vdo in, but maybe that has something to do with the miles not counting? this is my spare cluster and i'm just trying to get them both spinning.
    new gears
    1989 LN106 Hilux / 3.0TD SFA
    1974 2002tii / stock
    2002 IS300 / 5spd LSD
  • jaywood
    • Jul 2010
    • 4528
    When you replaced the gears were they broken?
    • mkcman17
      • Jul 2010
      • 8240
      well, yeah...that's why i replaced them.
      • rcfanatic
        • 490
        Did you ever resolve this problem? If so what was it?
        • nirenandrews
          • 26
          hi, I am facing the same problem, mine was working for some time but now it stopped working, I havent opened it yet, if any one can give a good solution it would be very useful for me too.
          • priapism
            • 1182
            I had the same issue, drove around for a bit then boom it started working again. We'll see if it's permanent, only put about 50 miles on it so far but it's rolled up every one of 'em since it came back to life.
            -Sean : 91 Calypso 325i : Castro Motorsports SoCal Spec E30 #33
