hard starts and occasional stutters?
  • 87-325ic
    • Apr 2006
    • 1198
    does this point to a vacuum leak? sometimes it takes a few cranks to get it running. sometimes it starts as soon as the key turns. sometimes i have to try 2-3 times and give it gas....
    also, while driving, it will have a sort of hiccup, like i took my foot off the gas pedal for a second, then resumed. this always throws the check engine for the lambda sensor getting out of range readings.
    any advice here?
  • llll1l1ll
    • 782
    Check your CPS (Crankshaft Position Sensor) and your TPS (Throttle Position Sensor) while you're at it.
    Those would be my first two guesses.
    Me: "I can't wait to redline my car!"
    Mark: "Didn't you just break a rocker arm?"
    Me: "Yeah, I don't think I've learned my lesson."
    Mark: "You never will."
      Intake leaks would be at the top of my list of suspects. At least until the car can pass a smoke test of the intake.
