welding inside car
  • jrobie79
    • Mar 2006
    • 2526
    welding inside car
    any precautions to take when welding inside the car? I want to weld some plats to my door to fit speakers a little easier, i have plates which have threaded holes so I want to permanently attached it to the door. any thing I have to do to prevent fucking up the electrical system aside from disconnecting the battery?
    1991 318i ---- 308K - retired
  • nrubenstein
    • 3148
    Pull the ECU for safety.
    2002 BMW M3 Alpinweiß/Black
    1999 323i GTS2 Alpinweiß
    1995 M3 Dakargelb/Black
    - S50B32/S6S420G/3.91
    1990 325is Brilliantrot/Tan
    1989 M3 Alpinweiß/Black
    • jrobie79
      • Mar 2006
      • 2526
      yeah meant to put that in my original post, unplug battery and ecu plug, i'll probably disconnect the wiring harness in the door jamb too just to be safe. but thanks!
        All that you need do is to disconnect the battery ground or positive cable and position the welder's ground clamp close to where the welding will be done.
        • StereoInstaller1
          GAS
          • 22679
          Millions of cars are welded on each year and no bodyshop in the world pulls the ECU.
          Closing SOON!
          Thanks for 10 years of fun!
          • Kingb
            • 928
            Very true and I do the same. When a customer comes in and I weld on their car I dont disconnect anything but I have fried 1 DME and it was mine. Go figure huh. But German shops have this surge protector that they put on the + and - on the battery.
            Originally posted by Nicademus
            My car beats off to that car. :bow:
