good job
Want to put a S13 SR20DET into your E30?
The SR gearbox has a solid mounted shifter, this is where the engine has to be until next year sometime when a shifting linkage can be made, custom oil pan, and brake booster removal/relocation (wilwood pedal box coming, so removal).
In other words, a hell of a lot of work just for a 1-2% change in wheel weight distro. This engine will be sunk deeeep in the firewall if any movement is going to happen though. So add 'remake firewall' haha.
And it's right in the middle, not 3 out of 4 in front.
Some very nice proper ali heatshielding was put in after that picture. Yes indeed the master cylinder got damn hot, completely untouchable after the short first-drive.Comment
defently if u can hook me up with some mounts or even an idea or specs that much appreciated. I have a friend with an sr20 in his 240Z .. he is gunna give it to me when he Fully Builts his other sr20w/GT35R. And i have another e30 laying around and been doing lots of research.. hopefully everything goes fine. and i get it the sr into the E30.
there was a website that sells the whole coversion kit for like 5grand??? i googled it i think it was K somethingComment
Nice. My harness only needed 4 wires to run. Took the rest of the stuff out. positive switched, positive constant, start signal, and ground.Comment
I've got an s30 I though about the swap in, but now the e30...awesome, so much to think aboutComment
Have you by chance had a chance to weight the car? I have a torn sr20 and a vvl head laying around. I am really curious how the weight distribution was affected. If you have the numbers, could you post the corner weights and front to back weight distribution please.Comment
