strut housing??
  • nicky51
    • Jan 2010
    • 158
    strut housing??
    Will strut inserts from a 325e fit an 87 325 ic? Just want to make sure they are same diameter. Thanks..
  • Hellabad
    • 807
    yes.
    Here is my photo gallery answering common questions about Ground Control Suspension, and e30 suspension problems in general.
    Ground Control Gallery
    The Ground Control facebook page: Dragged, kicking and screaming into social media to see what happens next.
    • Massive Lee
      • Sep 2006
      • 6785
      Yes. As far as I remember, the only akward inserts are from the 1984-85 M10 318i. Then they all are the same 51mm inserts.
      massivebrakes.com
      • nicky51
        • Jan 2010
        • 158
        reply
        Ok.Thanks guys..
        • Jean
          • 18228
          And also be aware of the 51mm housings with NO abs holes.
          • Adrian_Visser
            • Jun 2006
            • 2823
            My '84 eta had small struts... I think. I thought everything from before 85 did.
            '89 Alpine S52 with goodies
            • Jean
              • 18228
              there are early 45mm struts, then 51mm w/o abs, and 51mm with abs... not counting the iX struts and e30 m3 struts.
