Red gauge needles
  • royalflush313
    • Mar 2004
    • 2070
    Red gauge needles
    I have my cluster out (partially) because I had to fix the 'Check Engine' light not coming on. Turns out one of the ground wire wasn't plugged in.
    Anyways, I thought that I would paint my gauge needles. I know lots of you have done this.
    There was a thread about the best method, but I can't seem to find that thread.
    So, should I:
    - Spray paint? (If so, what kind of paint, color did you use?)
    - Brush on? (same q. again)
    And lastly, any tips for taking those needles off safely? I know that they just pull off, but they are fragile, so I dont want to put a bend/crack in it.
    TIA!
    EDIT: I want a satin look, not a shiny/gloss red. Spray painting seems like a way to go, because i want a nice smooth surface.
    I just wanna get it right the first time 8)
    EDIT2: Also, I find the cluster to be pretty dim at night. Anyone find a solution to make it any brighter? (Yes I know about the knob control). Bulb replacement perhaps?
    ~ Go Canucks Go! ~
  • Jordan
    • 12912
    The standard wattage bulb already melts the plastic diffusers in the cluster. A higher wattage bulb would be a really bad idea.
    I recent went with red needles to match my VDO gauges.
    I used red vinyl pinstriping, applied extra wide, then cut to exact size on the needle with a brand new xacto blade.
    This method works brilliantly, looks fucking awesome, and is perfectly removable later on if you should choose.
    It might take you a few tries to get the cuts perfect. If you mess them up just peel it off and try again.. you get like 50+ft of tries with most pinstripe rolls.
    https://mtechniqueabs.com/
    • royalflush313
      • Mar 2004
      • 2070
      wow, good idea. Never thought of that one.
      Thanks for the advice on the bulbs too.
      Did you snap any pictures of your new gauge?
      ~ Go Canucks Go! ~
      • royalflush313
        • Mar 2004
        • 2070
        it's hard to find good tape that is not glossy.
        For those that painted theirs, what paint/paint method did you use?
        ~ Go Canucks Go! ~
        • Pieter E30
          • Jan 2005
          • 48
          I did my needles recently, and the dials aswell!
          • Speed25
            • 39
            Pretty good idea, Jordan. I used Testors model paint and it came out pretty good. Incidently, I tried my red touch-up paint first, thinking it would match the car. It looked terrible! Seemed like the paint was too think, glossy, lumpy, something.
            I agree with the cluster bulb thought. My old e30 had dim lights and I tried 2W-higher bulbs. They looked GREAT but started to melt the orange stuff right away. Bad idea!
