brake lining light- diagnosis , already replace sensors, don't want to pull bulb
  • clydesdale
    • 631
    I don't want to remove the bulb and would like to diagnose why the light is still on. There is continuity at both sensors. Plus, I changed out the sensors with other spare sensors and the light still stays on. How do I check to make sure the wiring is working properly? Thanks.
  • Quadrajet
    • Jul 2008
    • 1278
    dirty or corroded female terminals? When I bought one of my cars the PO stated the pads were done. He failed to mention the sensors were removed and the connector exposed to the elements.
    • DaveSmed
      • Apr 2007
      • 1406
      With the key on, are you getting 12v at the connector for the front sensor?
      -Dave
      2003 Lincoln Towncar | 1992 BMW 325iC | 1968 Cadillac Deville
      Need some help figuring out the ETM?
      • clydesdale
        • 631
        No, 12v. How do I diagnose rear problem or front problem? Thanks
          Check continuity from the instrument cluster's C1-21 to C2-26 pins. If there is continuity there the fault lies in the cluster. Otherwise there is a wiring fault in the sensor circuits.
          • DaveSmed
            • Apr 2007
            • 1406
            jlevie is right again, (I think hes a robot to be honest).
            But, Since your already screwing around with sensors, check for 12v at the rear sensor. If its not there, there's a resistor in the cluster that is particularly fond of suddenly becoming "well-done". A 220 ohm resistor of greater wattage should fix you right up.
            -Dave
            • clydesdale
              • 631
              I did not have continuity between blue 21 and white 26. How do I tell if the wiring fault is in the front or rear?
              • DaveSmed
                • Apr 2007
                • 1406
                -Dave
