gas leak front drivers side
  • richardkeith97
    • 1693
    I just noticed I had a good amount of gas leaking right where the frame kicks up on the front left. I rally need to get this fixed tomorrow. I followed the fuel line from the fuel rail down to the metal line that I could see under the hood. I can't see any signs of anything leaking. Does anyone have any ideas? Btw it's an 85 eta. Idk if that makes a difference. Thanks for the help.
  • browntown
    • Jun 2004
    • 3524
    thats where some fuel filters are hidden. On top of that you have all sorts of fuel connections right on that frame rail. Jack it up, replace the filter, and while you are at it replace the rubber fuel lines to your fuel rail. Make sure to get High Pressure fuel injection hose. Technically the bmw stuff is metric, but if you take down a piece of the old hose they can match it closely with some sae sized stuff. Use good clamps.
