Idle ramps to 2000 rpm despite new icv and hoses- please help.
  • clydesdale
    • 631
    I replaced the icv and the main hose to the throttle body and the elbow off of the icv. The idle could be fine at time and then if I bump the throttle to 1500 rpm or so, it will stay up there. Also, if I turn the a/c on, the idle will ramp all the way to 1800 rpm. It does seem the if I push on the throttle position sensor wires or the body of the sensor, it seems to have an effect. If I unplug the icv, the idle will drop. Any suggestions? Thanks.
  • Quadrajet
    • Jul 2008
    • 1278
    What model E30 you working on?
    • clydesdale
      • 631
      1987 325is
      • Danny
        • 14216
        TPS or ICV installed backwards.
        • clydesdale
          • 631
          As far as I can see, the icv will only fit one way. I did not touch the TPS yet.
          • Danny
            • 14216
            Also, vacuum leaks.
