a/c condensor replacement- use oem or different design? r134a
  • clydesdale
    • 631
    I need a new condensor. Some has said that the oem is not adequate for r134a. But, I really do not want to do the customization for a parallel flow condensor. Any thoughts on which way I should go? Thanks.
    Use the OE condenser and R12 or an R12 equivalent (like Freeze12).
    • StereoInstaller1
      GAS
      • 22679
      ^ precisely what I was gonna say.
      Closing SOON!
      Thanks for 10 years of fun!
      • clydesdale
        • 631
        R12 is too expensive and I only have a little left. I want to retofit and be done with it. I can get r134a at walmart all day long for cheap. From what I understand there is no equivalent to r12. You either use r12 or don't bother is what I have been told. So, I flushed everything and want to start fresh with a retrofit.
        For those that are using 134a and the stock condensor, is it adequate?
        • scottinAZ
          • Dec 2009
          • 1312
          mine is retrofit with the stock condenser, and in phoenix heat gets as cool as my other vehicle with factory 134 ac. set your aux fan for high speed operation only (a search on here will come up with how to), as this will increase the airflow over the condenser and help with the cooling at low vehicle speeds
          I saved 15% on my Bimmer parts by switching to ...
          • StereoInstaller1
            GAS
            • 22679
            Don't even think about R134, go Freeze12. Far better than 134, just as cheap and they make a drying agent so you don't even need to replace your dryer.
            Closing SOON!
            • Garageaholic
              Freestyle Fabricator
              • Dec 2005
              • 5204
              I'm bringing this back, but I'm using an m60 compressor which is made for r134a. I plan to change all of the o rings......and use freeze12. Is there any issue with using freeze12 on an r134a compressor?
              Recent Rebranding!!
              E30 SM62/S62
              E30 M60 V8
              E30 M30 Big 6!
              Instagram.com/garageaholic
              Youtube.com/garageaholic
