First let me say I own a 1991 318is and I'm no mechanic but can do most of the basics (oil, brakes, belts, and rotors change).
The other day I started my car and heard a slight knocking sound coming from the motor. I then checked the oil and it showed a little less than half on the dipstick. I didn't think too much of it since I was planning to drive home (22miles drive) to change my oil anyways and I didn't think it matter much if it was slightly less than half. While driving home that day, I didn't hear any knocking at all.
Before starting my oil change, I parked the car for a few hours and didn't drive anywhere till I had to drive my brother to the bus stop which was 4 blocks away. So while I was driving, I heard noises coming from the motor but this time it was louder. When I got home and parked my car in the driveway, I notice that the knockings sound got louder and this time I also heard squealing sound like a loose belt.
So I decided to let the engine cool off and change the oil in hopes that my problems will go away. I also took off my AC belt, thinking that the squealing is probably coming from that since I did install the belt not too long ago. After completing my oil change and removal of the belt, I started the engine and the squealing got even loud and it idles rougher than before. I notice after i changed the oil, my fan clutch spun very slow and then all of a sudden stopped. I then turned off the motor and started it again and the problem was the same but this time the fan clutch didn't spin at all.
So now my problem is that I'm not sure what's wrong with the car nor how to fix it. I think it's the fan clutch that is causing all this but I'm worried that the low motor oil had something to do with it too. I've been searching the forums for days trying to see if anyone else ever had the same problem but didn't find anything. I was hoping that someone could give me some advice and input on what to do and how to diagnose the problem.
Thanks ahead!
Thanks ahead!
