Blinkers don't blink
  • dball4
    • 560
    So like the title says. My blinkers work but do not blink when my signal is locked to one side or the other? Im in highschool an not much of an electrician. What should i look at? Could it be a kind of fuse or something?
    Thanks
    1989 M3
    2008 135i 6sp
  • audiquattrot
    • May 2008
    • 3836
    its either a relay that attached to the turn signal switch/stalk or the stalk itself. Just buy a used stalk w/ the relay intact. Swap it out Did the trick for me on my 1st e30.
    www.instagram.com/snwmble
    #snwmble
    Current:
    '05 BMW M3 - Silver Grey/Imola Red
    '90 BMW 325iX - Sterling Silver/Houndstooth sport(5-speed converted)
    '15 Mini Countryman - Blazing Red/Carbon Black
    Past:
    '01 Audi Allroad - Light Silver/Platinum Saber Black
    '88 BMW 325iX - Diamond Schwarz/Silver sport *Sold*
    '01.5 1.8TQ - Brilliant Black/Nogaro Alcantara ...after 8.5yrs, *Sold* =(
    '90 BMW 325i - Schwarz/Tan sport *Sold*
    '89 BMW 325ix - Diamond Schwarz/Black sport *Sold*
    • dball4
      • 560
      ok ill check on that. im pulling parts from a buddys 91 325i so he should have one
      1989 M3
      2008 135i 6sp
      • audiquattrot
        • May 2008
        • 3836
        yeah this is all you need.
        #snwmble
        Current:
        Past:
        • AndrewBird
          The Mad Scientist
          • 11897
          Could also be a ground issue. If the ground at one of the lights is bad, the light will ground through the second filament and not flash.
          • dball4
            • 560
            Alright. So if i use a ABS and OBC lever will it still work in my 325e? its an 85. It doesn't have ABS but it does have the 13 button OBC
            1989 M3
            2008 135i 6sp
