So the car was running awesome and everything was ok, everything sounded good, drove good, temparature good, oil is good, everything was ok, as i was on the highway the revs began to twitch i would say, they would go down a couple hundred and back up, the problem got worse and the car shut down, i pulled over and let it sit for a bit and turned it back on, drove it all the way home when i got home the car began to idle roughly when i was stoping or on neutral, i thought it was the fuel filter being clogged up so i changed that, after i changed it i started the car it started and after about 30 seconds it shut off. now i cant get it to start, so i checked to see if there was fuel in the filter, and that was good, i believe that means the pump must be working, and then i checked the line that goes into the engine and there was fuel in that as well, the battery works fine as well so i just dont know whats next, any ideas guys????
thanx for any coments or opinions
