after i change the brake fluid and fix my gas meter the speedmeter, mpgmeter and radio doesn't work anymore. it was working before. i checked to all fuse, still good. during the brake fluid replacement and removal of the gauge (to fix the gas meter) i unhook the -+ battery couple times, rip out the brake lining wire from the pads. there couldn't be anything that would cause the speedo, mpg and radio to die. the mpg is jumping from 0 to 40. it is suppose to be around 30-15 when driving. any clue guys?
speedmeter, mpg meter, and radio problem
Tags: None
is it the speedometer or the tachometer? if it's the tach (rev counter) then it's a fuse. i cant remember which one off of the top of my head, but one of the fuses will take all 3 of those things with it when it goes.
Originally posted by ROLLingKINGi have a bronzit and plan on making it look sweet.Originally posted by slammin.e28Moral of this story?
If you drive your e30 on stairs, you're gonna have a bad time. -
fuse 12 take speedmeter and radio/stereo..i already check the fuse and its fine.Comment
i just found out my odometer is not moving either. can broken gear from the odometer cause the speedometer to stop working also?Comment
Randall Racing and Engineering
Acworth, Georgia, 30101
http://www.facebook.com/RandallRacingandEngineeringComment
By "gas meter", do you mean the fuel gauge? Sounds like you had the gauge cluster out? I'd start by pulling it again and making sure it's all plugged in properly.
Also, did you put a meter across fuse 21, or just eyeball it?S52-Powered 1987
sigpicComment
yeah the fuel gauge. i have pull the cluster out more then 6 times. everything is plug in tight. no, i didn't touch any fuse until those were out.Comment
update: i found out the aftermarket alarm is connect to fuse 21. Also, today i was driving and out of no where everything was working again, but its dead again. the good news is that my gauge is not broken and the bad news is that, there is an electrical problem.Last edited by mr.vang; 10-28-2010, 01:10 PM.Comment
