Spark plug wires...why the difference? Ignition coil too...
    Why do places like Bav and Euro Depot, etc all have seperate wire sets for the e and i? I swear I'm running i wires on my car. 7mm wires I grabbed from some salvage yard. They sure seem to be working...anyone?
    Also, is 8mm worth a step up from 7mm? I'm just trying to find little things to upgrade on while I'm replacing them - I know it may not be a HUGE difference (read: im not expecting a 5whp gain) but if it's even remotely noticeable...
    One last question. Upgraded ignition coils. Mine is old, and ugly. I found an Accel universal super coil that's chrome...any gain there? Anyone else running an aftermarket coil? It's cheaper than stock too...
    I cars use a sensor on the number 6 plug wire that is included brand new, that the eta's don't need so other than that they are identical(the plastic housing differs betweent he years)
    85 325e 2.7 ITB'd stroker
      Sooo...does the e engine just ignore that sensor? Is it ok to use I wires? What plastic housing are you talking about when you say they differ?
        Yes you can use I wires on an E, just cut that little sensor ring off the #6 wire. The plastic housing is the one that runs along the valve cover.
        Adam Fogg- '88 M3
        Common sense- It's the new 'gifted'
