Car behaves like a bucking bronco at low speeds
    While driving at slow speeds at my car behaves like a bucking bronco. No real issue if I'm just excelerating thru the gears even though I think it could be smoother.
    So, is this possibly a transmission issue, throttle linkage issue, something else?
    Your thoughts/inputs would be greatly appreciated.
    Thanks.
    - 90 325is, 5 spd
    Has it always been doing this or just recently? Only when cold?
    1991 325iS turbo
      It's been doing this for quite some time now and it exhibts the same behavior with the engine cold and at operating temp.
      - 90 325is, 5 spd
        Did you pull the head off at any point? Is it backfiring into the manifold? Mine did this when the timing was 180 degrees off.
        Originally posted by LJ851
        Feedback
          Did redo the head when I got the car due to a broken rocker arm. Doesn't seem to be backfiring tho. Perhaps I need to re-adjust my valves.
          - 90 325is, 5 spd
            Is the idle rough or unstable? If so I'd suspect intake leaks and or a problem with the AFM. It could have a worn spot in the resistance track or a stinking vane.
              Agreed, take a sniff around and find out
              1991 318iS
              1992 911
              2006 330i 6-Spd ZSP people hauler
              Gone:
              1989 M3 S50B32, 6-Spd
              1990 325ix 5-Spd
                Found a broken hose under the throttle body. Fixed it so will just have to continue to monitor. Also had the valves readjusted so am keepin gmy fingers crossed.
                - 90 325is, 5 spd
