Hi all,
I have an intermittant problem with my 325. It will sometimes surge while driving. If I press the clutch it will rev up to around 3k rpms and then back down. It's only done it twice, but both were recent. The first time I turned the car off and it was fine when I restarted it. The second time I just drove it hard and it was fixed by the time I got to 4th gear. I checked for vacuum leaks and found none. When it was happening, you could just barely touch the gas pedal and it would surge. The throttle cable seems fine. Any ideas? ICM?
Thanks,
Mike
Thanks,
Mike
