So guys i replaced the fuse number 27. Still doesnt work. It just went out all of the sudden. Any ideas guys? I can use the lock on the trunk fine but the doors dont lock or unlock. When i unlock or lock from the door though they all work.
Locking from the trunk went out!
Tags: None
shot your control module... maybe.... you could check continunity between module and rear lock on all the wires.... (behind/below drivers kick panel) if there is continuity the module had been shot.... oh and if you are pulling the module out make sure the battery is disconnected they are desigend to unlock the car in an accident (roll over) and once that happens they wont lock again -
