Looking for some *more* ideas. I have a rattle that seems to originate from the lower left below the windshield area, eg the wiper motor region.
It almost sounds like a door window is loose in its frame or like someone forgot a socket in the wiper motor compartment. but it's not.
It is something so loose that it rattles over expansion joints at 5mph.
I've replaced the strut bearings, trans and motor mounts, replaced the sunroof seal, replaced the door brake (I was excited about this one, I was sure I found the source when I found the broken door brake spring), opened the door while driving to see if it was the latch or hinge, replaced the sway links and bushings.
About the only thing I haven't checked is the front sunroof drain hose to see if it's loose & disconnected, only because I'm not sure how to.
:crazy:
:crazy:
