'big six' motor mounts
    i was on bimmerforums and someone mentioned using 'big six' 5/6/7 motor mounts to avoid the catastrophe associated w M20 mounts -- can anyone comment ?
    --Hayden--
    '87 325 coupe- Trak Rat
    '93 318is- 4cyl's of fury
    '92 Integra GS-R--yeah, its fast..
    www.G2IC.com
    no-one ? ..
    --Hayden--
    www.G2IC.com
      Just order some of the urethane mounts from IE.
        You need E12 530i or 528i mounts. They have 2 locator nipples, E30s only use one, so cut one off. They are the same size but a stiffer material and thus last longer.
        Adam Fogg- '88 M3
        Common sense- It's the new 'gifted'
          Still don't believe me..??? ;)
          Check this link:
          (posted before many of you were out of diapers :o :o )
          Bret.
            Bret -- i was able to find many 'back in the day' shots of the you & e-21/320.. thanks for the tips on the mounts
            --Hayden--
            www.G2IC.com
