First post here but I've been around the online community a while. I also posted this on bimmerforums.
After doing a bunch of work on the car (91 325iC w/JC chip) started it up and it idles steady at 2K rpm. Valve train seems a bit noisy also but it might be my poor work doing a valve adjustment.
Timing belt change went pretty much by the book with no parts left over, not even a washer, and I didn't lose any tools (yay!). I did a lot more than a timing belt change (water pump, hoses, belts, etc.) and I did take the throttle plate out to clean it but that seemed to go back together ok with an even hairline of light all the way around the plate when closed (it closes all the way to the set screw). I also wrapped tape around part of the wire on the spark plug harness that monitors one of the spark plug wires and goes to the other side of the engine. The cover was damaged with about an inch of wire exposed. The wires still had their individual coating and seemed okay. Timing belt seems to be the one thing I have any real doubts about.
So questions:
1. If the belt is a tooth off could that cause high idle? I'm thinking maybe the car thinks the timing is advanced causing high idle. But I would have guessed it would run much rougher.
2. Could being one tooth off cause any damage? It seems unlikely that there would be so little tolerance for error.
3. What else might cause the high idle after the work I did?
I'm going back to check the valve adjustment although I thought I did a pretty good job at it. If it still has the high idle after that I plan to tear it apart and check the belt again. Hopefully you guys will come up with something.
All thoughts much appreciated.
Steve
So questions:
Steve
