motor mont is trashed..
  • Switch
    • Oct 2004
    • 158
    well, today i jacked my car up to change oil, and see where the new "bellhousing" oil leak is coming from, could not find where it was coming from, it was ust slowly seeping out of the little hole in bottome of bellhousing....
    well long story short, i noticed that my passenger motor mount is sheared in half... grrr,, probly due to the roughness of not have an eccentrict sn a valve *cough* *growl* but yeh, what should i check on when i install a new one.. could this have busted the rear main seal in the crank...
    anyway just jack up engine, take old mount of, put new one in right.. thanks..
    </img>
    Schnitzel Not Rice....
  • trent
    Re: motor mont is trashed..
    nope. they just sheer. you arn't special. Just means you lack doing general maintence.
    • Switch
      • Oct 2004
      • 158
      wtf are u talking about? the bmw mechanic who did my valves last did not tighten the numbe 1 intake eccentric..
      </img>
      • Jays323i
        • Dec 2004
        • 40
        motor mounts
        I have a new pair of mounts if your interested $25 shipped.
        Jay
        • Switch
          • Oct 2004
          • 158
          thanks dude, i'll PM tomorrow if i want them, i work at dealership, might get decent discount, but 25 sounds pretty good lol...
          question, i have heard mounts from other cars (7's and 5's) will work better then the m20 mounts, anyone heard the same?
          </img>
          • AdamF 88iS
            • 2051
            E12 530i or 528i mounts.
            And like trent said, don't go after the guy saying he's responsible for your mount. I'd make a bet that 99% of E30s on this board need new mounts if they haven't been already changed. They all do that.
            Adam Fogg- '88 M3
            Common sense- It's the new 'gifted'
            • Gus
              • Jan 2004
              • 285
              its always the right hand side too....i was waiting for my urethane ones to come and had a crash last thurs...motor went into my brand new radiator! hopefully insured though!
              JUNGL3
              1990 "333i" Sport
              • DEV0 E30
                • Oct 2004
                • 8893
                I had a close call, fan brushed the radiator some, hopefully it will last a few more months. Motor mounts sheered aswell.
                • Switch
                  • Oct 2004
                  • 158
                  great thanks, sry i guess i was just a little ticked last night...
                  anyway, thank god my motor did not ram into my raditor, it does look like its barly sitting on my steering rack, now the leak i had in it, has gotten bigger... god i have so many leaks lol.. 2 big ones, (oil) and another mid one (power steering).. oky doky, so e12 520's will fit directly in with no probs. i'll get a price on those as wello, see if they are same price.. would get some poly urathanes, but there so expensive lol
                  </img>
                  • Switch
                    • Oct 2004
                    • 158
                    im sry.. wtf am i talking about lol, i just woke up, not thinking straight,
                    ireland engineering has some poly uros for like 35$... they help with anything else besides... never breaking lol,
                    </img>
                    • finch
                      • Oct 2004
                      • 279
                      Ive had to do engine mounts on all 3 e30s that ive owned. all were in two peicies when they came out.
                      • TimmyBigHands
                        • 260
                        Mine too, just finished actually.
                        • Switch
                          • Oct 2004
                          • 158
                          my god, what a pain.. i figured it would only take a few mintues.. but* it took 45.. i ran to work (knew they had a floor jack) and did it in the parking lot.. diod not ahve time to let headers cool, so burned my finger first try lol.. anyway, finally got underneath the car after jacking up engine.,. and it was in 2 pieces, and what a pain to hold the left over rubber and try to turn nut at same time,,, thing that took me the longest was, the engine would not come straight down on the bolt, had to sit there screwing with jcak (up down, kick, up, kcik, turn down) for about 25 mins until finally! got it..
                          PS. after lfiting engine, the heat sheild fell off... and i cannot for the life of me figure out where the f** it hooks to, i wrapped the mount in aluminum foil,, (i know i know) anyone got a pic of the heat shield while on the car, wtf does it hook to, i did not pay attention to it while taking the bottom ut off...
                          </img>
                          • DEV0 E30
                            • Oct 2004
                            • 8893
                            The little heat shield?
                            Has two small bolts with nuts and only really goes one way onto the passenger side motormount, I'm sure you can get to it like I did, removing the coolant overflow/tank may help.
                            • AdamF 88iS
                              • 2051
                              Are you talking about the black metal plate that has the heat shield bolted to it? It hooks to the lip on the subframe and has the mount stud going thru it to hold it in place. Those are important, they prevent the the motor from sliding back and breaking the mount again, just like the bumper on the tranny prevents it from sliding forward.
                              Adam Fogg- '88 M3
