Just finished installing a timing belt on my 89 325is. Replaced the spark plug wires, spark plugs, ignition cap/rotor, v-belts, flushed the cooling system, etc.
I think it might be worth mentioning that I pressure washed the engine bay once I took the timing belt out.
The first time I drive it the car drives great except it hesitates like its hitting a rev limiter at 4200rpm?.. I call a friend and be mentions double checking the crank balancer to make sure it is true. I pull everything out, resecure the balancer, and now when I drive it hesistate at 5k.
Could this be the CPS?
