Header panel lights
  • Ceeker
    • Sep 2009
    • 2821
    Header panel lights
    ok, so I get this vert recently; and the both lights on the left side weren't working. the header panel low beam light was on. The high beam indicator on the instr pod was out as well. I took out the pod changed some bulbs and then installed again. Well God only knows what changed but all my lights worked again. BUT! the header panel is still showing low beam light error. We had a cold snap the other day and when I put the lights on the low beam check panel light didn't come on immediately. I thought maybe this was another self correction again. It doesn't seem to go out. so I changed the check panel as well to test to see if this was the problem. it didn't change anything.
    I did notice someone may have cut and reconnected the wires to the low beam side plug
    any ideas as to what it could be?
