[IMG]
Big round thing ate my wires!
The big round thing (harmonic stabilizer?) ate my reverse light wiring. Anyone know how this is supposed to be routed/secured so after i fix it i dont run into this problem again. Also what would be the best way to fix this?
[IMG][/IMG]
Tags: None -
I can't tell exactly what I'm looking at here...
Are you talking about the driveshaft/guibo eating through it essentially? Not sure what else would be rotating back there...
There should be a connector on one side, and a plug on the transmission. You may be able to just get a new section of that wire/connectors. That's what I did. (had to get a new trans and just happened to have the wire with it)
It looks like the guibo on the top right then that big round thing goes around your driveshaft? That's odd, I don't have one of those. Anyways there are some clip like things (kinda like how a paper clip works) on the transmission housing. I have mine in along there and pulled tight.Originally posted by z31maniacI just hate everyone.
No need for discretion. -
well ziptie the wires out of the way-FREEDOM- is cruisin at 80, windows down and listening to the perfect song-thinking "this is it"
-The Beauty in the Tragedy-
MECHANIC SMASH!!- (you all know you do it)
Got Drop?? ;-)
Originally posted by JinormusJBut of course
E30s are know to be notoriously really really really ridiculously good lookingComment
That wire section is usually clipped to the aluminum shifter carrier seen above. You can just ziptie it to it. And yes, that is your harmonic balancer.sigpicComment
Last edited by 87e30; 11-24-2010, 04:59 PM.Originally posted by z31maniacI just hate everyone.
No need for discretion.Comment
Nice, that is super helpful. Did you just rebuild your shifter? Im about to embark on that journey too. Probably wont do a short shift yet, or the nice shiny aluminum bit, i have heard it is really nice. Pretty spendy though. Thanks for the help.Comment
I was looking at that too
http://www.turnermotorsport.com/html...&subcat_id=198
dssr, double shear selector rod. supposed to really tighten things up. btw love your car, mine is the same colour! yours is the first one i have seen in "german racing green" other than mine. I know there is an official name but my buddy coined that term, i think its fittingComment
woah, they made plastic clips? All of mine are metal, and they are a bitch to remove and install...Comment
