Strange Ticking...
  • boricuabimma'
    • 566
    Strange Ticking...
    When my car's moving I hear a strange ticking coming from the front driver's side wheel or whatever... When I brake the ticking stops, so does the vibrating. What could it be??
    When I'm over 60 there's no ticking nor vibration
    Thank You
    1994 BMW 325 i/Canon Rebel XT/28-135mm IS f:3.5-5.6/Canon 50mm f:1.8
  • boricuabimma'
    • 566
    n e 1?
    • boricuabimma'
      • 566
      awww c'mon... I know at least one of you guys knows what this is...
      • bkelsey86
        • 1173
        rocks in your tread :?
        • MonkeyM20
          • May 2005
          • 29
          Possibly a nail? that would be the obvious thing to look for...
          Ive had wheel bearings go bad and they make a whining noise. i dont think its that.
          Jack up your cars front end, and spin the tire from where you suspect the noise to be comming from. if you can hear the noise. have some one else spin the tire and you look under the car with a flashlite. feel for vibrations and ticking that might lead you to the problem. BUT PLEASE be careful, make sure your car is securly jacked up before you start poking around and shaking things underneeth.
          i hope this helps.
          -josh
          E30's Rock!
          • MonkeyM20
            • May 2005
            • 29
            Oh check your control arm bushing too. If you push and pull on your wheel, there shouldnt be any movement from yout control arm bushings. if they do move around the probly need replacing.
            -josh
            E30's Rock!
