To those who did the M30 AFM swap
  • Erick
    Official R3V Drifter
    • 11169
    Do you guys change EVERYTHING from one AFM to the other or just the circuit board?
    I read the Dave's AFM article, but I recall someone saying not to mess with the gears on the M30 AFM.
    Thanks,
    Erick
    ..::Support FullOpp::..
    FullOpp Stickers for sale!
    Feedback Thread
  • ZiMMie
    • Jun 2004
    • 968
    i had m30 afm lyin around. Plugged it in on a local members E30 its started no problem but i needed to adjust the idle on it. so if u have 027 afm it should work u might need to adjust the idlin on it.
    www.stancefactory.com
    • Erick
      • 11169
      Well I'm just doing the circuit board and lets see how it works. I've been thinking about this but I havent tried it yet:
      Does the intake boot fit the m30 AFM being relatively bigger than the m20 one?
      Feedback Thread
      • UNHCLL
        • 8790
        bad plan.
        you cant do that.
        The ECU will think its getting the volume of air from a stock M20 AFM.
        You are really feeding it a larger volume of air since its the m30 AFM.
        This = Lean condition
        Lean = bad.
        you already have moronic 1.3 in your car Erik, so find a 1.3M m30 afm, and that will plug right in.
        Below the radar...
        • BMW BMXER
          • 2325
          I plan to do this once I go to a junk yard and grab the m30 one. My afm now is a lil funky.
          Id also do it when I have injectors though.
          Sold it.
          • Erick
            • 11169
            bad plan.
            you cant do that.
            Lean = bad.
            hmmm I doubt e28s have 1.3 motronics. The AFM donor was an e28.
            Feedback Thread
            • ZiMMie
              • Jun 2004
              • 968
              No u need to strech (heat/fire) the boot it wont fit it.
              • DamnDog
                • Dec 2004
                • 10
                what do you guys think is the best way to deal with the whole boot being to small problem... should I heat and streach the boot, or should I try and make somehting else like the aluminum elbow in Davelength.com.
                basically my question is, will i be restricting the amount of air to my engine by using the boot that was really made for the amount of air being passed through the m20 afm
                thanks
                • bichmgnt
                  • May 2005
                  • 42
                  Dave Ireland told me just throw a new boot into some boiling water to heat it up and stretch it over the m30 afm. You won't be restricting anything since the AFM hole is still smaller than the boot.
                  Steve
                  Tomahawk -
                  When you care enough to send the very best.
                  • UNHCLL
                    • 8790
                    bad plan.
                    you cant do that.
                    Lean = bad.
                    e34
                    Below the radar...
                    • Erick
                      • 11169
                      So my e28 one is useless?
                      Feedback Thread
                        • 37829
                        If you get a 027 M30 AFM, it's a direct plug in
                        As far as the boot guys, use a ehat gun and ehat up the end that goes on the AFM, you should be able to get it on no problem after that.
                        Classic BMW Specialists
                        Grover Beach, CA
                        www.BimmerHeads.com
                        • rwh11385
                          lance_entities
                          • 18403
                          Or just be a man and use a screwdriver and no heat to stretch it.
                          Pussies. Summer's Eve has its new warming solution for you. But you shouldn't need the heat to get it......just your manhood and a flathead.
                          • PeaveyBassist
                            • Sep 2004
                            • 3511
                            I'm not usin my manhood to stretch a rubber boot around a metal circle... I dunno about you guys though.
                            Will
                            RIP e30 (brilliantrot '91 325i) 11/17/06 Byebye: 8/21/07
                            Welcome e30 (brilliantrot '90 325is) 12/23/06
                            DaveCN = Old Man
                            My signature picture was taken by ME! Not by anyone else!
                            If people keep quoting me in their sig, I'm going to burn this motherfucker down.
                            • rwh11385
                              lance_entities
                              • 18403
                              It feels good. A really cheap fleshlight.
