Gas Smell
  • HowzeR
    • 67
    Gas Smell
    Hey, I slightly smell gas when I turn on my heater. I had the dealer replace the two fuel lines in the engine. Any ideas what could be causing this? Thnx!
  • bmwguru007
    • 561
    Take a look at the work they performed, if you see any leaks don't drive the car until it's fixed. If everything looks alright, they might have spilled a little fuel and didn't clean it up that well. In the second case it should go away after a few days or so. If the smell doesn't go away take it back to the dealer and have them look at it again.
    • HowzeR
      • 67
      hey
      The lines have been replaced almost a year ago. I was taking my car back to Mr Transmission to drop it off over night for them to work on it tomm morning. But I smelled it when I had the heater on as soon as I passed a Texaco gas station. My gf thinks it was just from the station, but I still smelled it like a minute later when we were driving away. It just start happening outta no where. Doesnt make any sense.
      • bmwguru007
        • 561
        Well she is probably right, but I'd check it out anyway. You don't want ---->:firehop:
        • mspiegle
          • 1026
          check fuel line to injector.
          same thing happened to me not long ago. dumb shit mechanic used the wrong hoseclamps... eventually ate away at the hose and gas was slowly squirting.
          Michael Spiegle
          '01 Ford Escape / Daily Driver
          '99 M3 / Track Car
          '87 325is bronzit / wtf car
          '06 Daytona Triumph 675 / Daily Rider
          • HowzeR
            • 67
            hey
            The dealer replaced the fuel return and delivery hose it says on my recipt. Dunno if this helps? I will check that out tomm though! thnx!
