rear axle no go into hub
  • stubble88
    • 79
    How in the hell does one get a remanufactured axle to go back into the hub? The teeth on the new one look like there powder coated and are not as polished as the one that came out.
    The old one goes in a lot easier.
    What are some tricks?
    This is the Cardone brand.
    thanks
    The first thing you do is to clean the splines to bright shiny metal. A small stainless wire brush, like sold at welding shops and Lowes, HD, etc., works well on the splines in the hub. For the axle small scrapers will be needed if it was painted. Finish the hub and axle with 400-600 grit crocus cloth. Every part of the splines (top sides, and bottom of the groove have to be bright and shiny).
    • ZM Blue Devil
      • Dec 2006
      • 13836
      Pc? They should be nice and shiney. It's a "perfect fit" with no play. So if it's pc'd that would be the problem. Post up some pics.
      Levent
      %20levent@gutenparts.com
      Ladies:
      • stubble88
        • 79
        thanks guys
        just wondering if this was normal
        I tried a wire brush but that crap would not come off
        why in the hell do they paint the ends? They should be greased.
        • Gooch
          • Dec 2006
          • 1674
          This is a common problem with the reman'd axles. IIRC, there are a few threads discussing them. Search it up I'm sure you'll find something.
          '91 318is - OBD-II S52 swapped - E30 M3 5-lug - 5x120 BBS RC090 (E39 Style 5) - TCK D/A coilovers 550/700 [SOLD]
          '87 535i - Vacuum brake conversion [SOLD]
          '93 525iT - 5-speed swap - 320k and counting
          '09 328xi - 6-speed
          • stubble88
            • 79
            well I had to give up and just put the old one back in which went right in without issue.
            almost two days waisted on this.
            now I have to pay to have it done.
            the splines are just messed up on the remanufactured.
            • KennyT
              • 542
              This is why you don't buy shitty remans. How much did you pay for the axle?
              • stubble88
                • 79
                So who makes a good one under $600?
                after the core charge refund
                $43 each
                • KennyT
                  • 542
                  Take your axle to a shop that remanufactures in house. If you were Michigan local I would reman it myself.
                    In my experience, no one.
                    The ~$100ea remans from Advance come close. But they have the wrong outer boots that will rub on the shocks and quickly fail. You can fix that for ~$100/axel by replacing the boots with OE parts.
                    • stubble88
                      • 79
                      i have a bmw mecahnic here in burbank who says he will do it for $160 both sides (installation)
                      going to see if he can handle these mushy splines.
