Battery hooked up backwerdz...hurp durp.
  • MaxBell
    • 1391
    Ok, so I have a friend's 325is sitting at my place right now. It was running fine a week ago, however, SOMETING TERRIBLE HAS HAPPENED!!
    This is a really long story, involving multiple people to blame but here is the short version.
    1. Old battery died.
    2. New battery was purchased.
    3. New battery was hooked up backwards. (+/- and -/+)
    4. Car was started, smokey smell and a weird noise were noted.
    5. Owner unhooked the battery, realized their error and called it a night.
    6. I came over, hooked it up properly, replaced 2 fuses, started the car first try.
    7. Let the car run, it smelled like burning in the engine bay, even after a few minutes of idling.
    8. Turned it off, but even with the key out of the car the battery indicator light stayed on.
    9. Got back to the car the next day and the indicator light was out and the battery was dead.
    I looked at the alternator and it looked like it may be cooked. Also, there are some little wires that are a little melty, going to the alternator from the battery. I'm going to replace that, but do you think that the car has been more severely damaged? Is it worth going through all the hassle of finding out what is wrong with it? It's probably going to go to the junk yard/part out if it's any more then $100-200 dollars repair.
    I know it's hard to diagnose over the interwebz, but we'll see what you all know.
    REMEMBER: Be safe and have fun is Rule Number 1.
    The Epic Unbuild of Clint Eastwood
  • grays
    • 1343
    wowser
    • CHIF8008
      • 3447
      haha ya umm hooking up a battery wrong causes a lot of problems, lucky it didnt fry more of the electyrical system/such as the headunit and anything else hooked up to the harness
      -FREEDOM- is cruisin at 80, windows down and listening to the perfect song-thinking "this is it"
      -The Beauty in the Tragedy-
      MECHANIC SMASH!!- (you all know you do it)
      Got Drop?? ;-)
      But of course
      E30s are know to be notoriously really really really ridiculously good looking
      • MaxBell
        • 1391
        Ya, we're actually just going to part it out. Never mind. If anyone needs anything off an E30, PM me and I'll see what's good. It's a 1987 silver 2dr 325is.
        • 328ijunkie
          • May 2007
          • 3961
          Alternator and starter likely pissed off a good bit as well as the wiring harness' to them
          Check Us out on Facebook
          Full Product Line Tuning
