I have an 85' 318i with the m10 in it...still. It has been having some misfire issues lately, but today, it went unresponsive to throttle and died on me. I was able to get it into a parking lot and let it sit for awhile and tried to start it up again. And wallah! It started, and instantly died. Tried a few more times and the most it would do it start, high idle, stabilize and stall right after. I checked my AFM connections, spark plug wire connections, cap & rotor, and all seem to be good. I tried to start it up after that and it wouldn't start, only cranked for awhile. Tried again and let it crank until it started and then I could smell the fuel from the exhaust telling me I'm not getting spark. I haven't had a chance to check the actual plugs yet since I just walked across town (small town) to get back home, but any other ideas you folks have? Possible coil problem? Thanks in advance for any insight and/or help
Edit: When it was misfiring, the MPG gauge would jump up past 40 and then back down to where it should be, not sure if that helps at all.
