Hardwiring V1
  • Rob
    • 8166
    Hardwiring V1
    I'm trying to hardwire my new V1, I'd like to use the check control panel in front of the sunroof crank. I dont have the full panel since I have a 318is, but I know its got power since it shows an SRS light due to my aftermarket wheel.
    Anyone know off hand which wires I should tap into? I'm out there with a voltmeter experimenting, but maybe someone can save me the trouble.
    available wires are:
    brown/black
    Purple
    Green/white
    Brown/Purple
    Thanks
    BEERTECH
  • Jand3rson
    • 37587
    There has been a TON of write-ups on how to do this, I used to have one but when I reformatted, I lost it. Try a google search or maybe on DTMPower, I think that's where I found it.
    • rs4pro3
      • 5808
      There is a wiring diagram but I can't tell if it's for the E36 or the E30 318is.
      But from it it looks like Grn-white would be a switched 12 volt wire. I'd still use a volt meter to test.
      85 325e 2.7 ITB'd stroker
      • Rob
        • 8166
        according to my voltmeter, i dont have enough juice up there, i guess since i dont have the real check control panel or power sunroof. cig lighter will suffice
        BEERTECH
        • rs4pro3
          • 5808
          Ya the cog lighter is wonderful, I've got my Air fuel ratio guage wired off it and my radio wired of some other 12 volt source under the kick panel. I'd check soem of those empty plugs under there as then you wouldn't need to run as much wire up to the headliner.
          • OreoGaborio
            • 1285
            i wired my detector off one of the stereo leads, so it turns on w/ the ignition... originally i did it off the cigarette lighter, but i found out that has power goin to it even w/o the key in the ignition
            -Pete
            LRRS/CCS#187 ECK-Racing, Ironstone Ventures, Tony's Track Days
            Pine Motorparts/PBE Specialists | Phoenix Graphics | Woodcraft | Moon Performance | RJ's Motorsport | Motorcycles of Manchester
            The Garage: '03 Tuono (Hooligan bike :naughty) | '06 SV650 (race)
            • Rob
              • 8166
              yeah i'm going to research into an ignition controlled lead, tomorrow though when i've got the soldering iron ready to rock
              BEERTECH
              • bmwguru007
                • 561
                I used that little accessory add on box next to the fuse box to hardwire my radar detector. I had to run a bit of wire through the firewall, but I figured it was easier than testing a bunch of wires inside the car. There are two wires that go into that box, on mine the red is always hot and the green is hot with the ignition on.
                • Rob
                  • 8166
                  thats a good idea, where'd you run the wires through the firewall? and are those accessory plugs constant on or ignition on?
                  BEERTECH
                  • bmwguru007
                    • 561
                    If you look down underneath the brake booster there should be a couple of holes you can feed it through. Take off the panels under the steering wheel and you will see a big rubber piece with a bunch of wires coming through. I cut a small slit in an extra part of that rubber piece to get the wire through. I also used some of that plastic wire wrap to protect the wire a little bit. One of the accessory plugs is constant on(red on mine) and the other is ignition on(green on mine). I'll take a picture and hopefully post it tomorrow night after I get home from school.
                    • bmwguru007
                      • 561
                      Sorry I haven't had a chance to take a pic yet. I'll take one this afternoon and post it as soon as I can.
                      • randomtask37
                        • 3154
                        man i wish it was legal in virginia to have a radar dector.
                        98 M3/4/5
