Hi, I did search and didn't see anything just like this problem...
The wiper fluid level check panel LED won't go out , I can't figure out why. I have tried the following to isolate the problem.
- Snipped off the fluid level sensor plug so I can twist the wires together/ pull apart and eliminate any variable issues with the actual sensor or plug.
- I have a good ground when testing the BR wire to ground.
- I get about 7 volts from the BL/VL wire to ground. Connecting this live wire directly to ground doesn't help.
The circuit per the Bentley manual is really simple but I don't know what to try next...? If I wasn't getting any voltage, I would try re-flowing the check panel solder joints but not sure at this point.
Thanks for any ideas!!
