Squeaky belt in a NV m50
    I'm a beginner backyard mechanic and am trying to find how to adjust the tension on the alt,wp, ect belt? a diagram would help.
    thanks
    1989 M3
    2008 135i 6sp
    Theres no adjustment you likely need a new tensioner
    sales@blunttech.com
    www.blunttech.com
    Like us on Facebook
      As noted above, the tensioner could be bad. In addition to that you could have a bad bearing in a tensioner a bad bearing in any of the belt driven parts, or an old and glazed belt. Remove the belt and check each rotating part for a rough bearing. When removing the belt you'll be able to tell if the tensioner is still good. If you don't find a problem with a bearing or tensioner, replace the belt.
        Ok here is a thought.. When its very cold the belt squeaks..And really intermittent not for very long. Then once the car is warmed up a bit i can't hear it come in at all. If I know my physics class correctly rubber contracts when heated?
        So I feel like the tensioner is doing its job possibly?
        1989 M3
        2008 135i 6sp
