Help Euro Analog Clock
  • Acehye559
    • 1033
    I think the clock maybe messed up but thought Id ask. It's weird because I wired the clock up just the same way bmw325csi has up on his thread:
    This is for the multi-function clock harness.
    Once you remove the mf clock you will see a harness which has about 12 wires, you only need 4. The analog clock has a # above each pin
    30-power
    31-ground
    58k-illumination power
    31g-illumination ground
    So what you need to do is grab the mf clock harness and cut these wires:
    red/white-power
    brown-ground
    gray/red-illumination power
    brown/white-illumination ground
    Sometimes the clock's light turns on but most of the time its off. That is when the headlights are on. And when the headlights are off it illuminates a little. So i dont know what the problem is. Maybe the light bulb? But it turns on sometimes. Maybe the wiring is loose but I played with the wires when it was on and it didnt make a difference. So i came to the conclusion that the clock is bad. Any ideas?
    Thanks
  • phreshkid
    • 4655
    Can you post a link of bmw325csi's original thread? I searched but i can't find him in the members list.
      • 37833
      It was very easy to find...
      Grover Beach, California
      BimmerHeads.com
      • phreshkid
        • 4655
        Dang it yeah I just found it. Sorry about that.
