Injector upgrade: which injectors??
  • RCWells
    • 3589
    I know that many have chosen to upgrade to Mustang 19# (Bosch Type IIs I think) but I heard it said that the E36 M3 injectors were a better choice, and perhaps cheaper.
    Some of you guys with some expertise in this area give me some feedback. I want to upgrade for sure, but which injectors to go with is the question...and why??
    Thanks
    [THE 501 club - Founding Member]
  • decay
    • 5637
    personally i think 19lb-ers are the right choice (and i picked up mine for $30, good luck finding e36m3 injectors cheaper than that), but here:
    past:
    1989 325is (learner shitbox)
    1986 325e (turbo dorito)
    1991 318ic (5-lug ITB)
    1985 323i baur
    current:
    • Mystikal
      Wheel Fitment Expert
      • 9602
      You want 17.5lb M50/S50 injectors. Note the M50 part, these things are everywhere and cheap. I personally paid $40 for a set of S50 pieces with 40k on them and looked brand new.
      You want these because they are ALL 4-pintle (very important) and a stock internalled M20 does not need any more than the 17.5 units provide.
      • SebSter
        • May 2004
        • 192
        but the 19lb ford ones are allrigiht as well no? i mean can they be worse than the 17.5 ones?
        1990 325ix
        • King Luis
          • Sep 2004
          • 737
          how complicated is the install for bigger injectors? is it direct install or is there tweaking you have to do???
          • Mystikal
            • 9602
            Yeah they're fine, nothing wrong with them at all. It's just easier to find the 17.5 ones being in the BMW community and you know they are all the proper Design II ones (the older Fords aren't).
            Easy to install, just tedious. There isn't much space to work with, and dropped things may take a while to find. The ECU adapts to the new sprayers, no other modification necessary.
            You should note that a stock M20 really doesn't need these, and wouldn't do much if anything (the only gains are if the stock ones aren't working 100% anymore). I installed them because my car couldn't get enough fuel at higher RPM with the mods. There is no point guessing if you need them or throwing mods at engines that you don't know you need or even give you gains (read: the entire aftermarket world does this crap). Get on a dyno and see if you need them.
              • 37832
              19 lb injectors are the perfect upgrade to go along with a M30 AFM, no questions asked
              Classic BMW Specialists
              Grover Beach, CA
              www.BimmerHeads.com
              • RCWells
                • 3589
                I have a Mark D 93 chip, am converting to an M30 AFM, and though I have yet to confirm this, I supposedly have an extrude honed intake manifold. I will also be running Supersprint headers in the not too distant future as well as an AFPR (though there is some question as to this particular mods' gains). I also have the old K&N hot air intake system. So all in all, I hope that the injectors will be a worthwhile addition to the package.
                • rwh11385
                  lance_entities
                  • 18403
                  meh, what do you know......but intraw3b gossip.
                  I'm with Jay now on the 4pintle 17.5# talk. If I gave too much of a damn, I'd swap.....but I don't think that is happening.
                  and for that matter, if you find cheap mustang injectors, go for them....who cares?!?
                  However, there are three reasons I'd recommend upgrading injectors:
                  1) M30 AFM
                  2) Mark D 93 Octane Chip
                  3) clicking stock injectors (might as well do the cheap upgrade yo)
                  • Mystikal
                    • 9602
                    Well that about sums it up. Word to the wise. ;)
                    • arsevader
                      • May 2005
                      • 1025
                      Finally someone believes me on this. ;)
                      James
                      • RCWells
                        • 3589
                        Sums what up? Did I miss something?
                        • rwh11385
                          lance_entities
                          • 18403
                          You should note that a stock M20 really doesn't need these....... Get on a dyno and see if you need them.
                          1) M30 AFM
                          Word to the wise......if you have a Mark D 93 octane......your M20 really wants bigger injectors. 8)
                          • RCWells
                            • 3589
                            Thanks for clearing it up. I thought that's what he meant.
                            • Mystikal
                              • 9602
                              LOL, sorry for the lack of clarity.
