Remote start button?
  • Bimmerfanatik
    • May 2004
    • 5349
    When I worked for Schneller I used a remote starter button that jumped the two pins in the starter to "flash" crank the engine. Perfect for speeding up the endless task of adjusting the valves.
    Where can I find one? Bav sells the factory one for 90 bucks. I'm just looking for one with alligator clips on the ends of the wires. Could be completely generic, just can't find anything...thanks guys.
  • e30sd
    Fistee
    • Jan 2004
    • 5517
    90 bucks? go to radio shack, buy a momentary contact switch and solder up some lengths of wire to it.
    • Bimmerfanatik
      • May 2004
      • 5349
      Not sure if just a plain ol' RS switch would handle the amps...have to check into that I guess. I thought about that though.
      Bav's plugs into the diagnostics port. Hence the price tag. :)
      • e30sd
        Fistee
        • Jan 2004
        • 5517
        dude i rigged one up, been using it for years. no probs what so ever.
        • Bimmerfanatik
          • May 2004
          • 5349
          Really? What pn/style or whatever? Much appreciated.
          • rs4pro3
            • 5808
            Jump pins 11 and 15 in the Diagnostic connector does the same thing and you don't have to reach down by the starter. Just buy two pins at the dealer that fit the plug, solder some wire and a switch up. Can come in handy for doing vavles, checking for spark from the engine bay,and other things.
            85 325e 2.7 ITB'd stroker
            • DanGillan
              • Mar 2004
              • 4061
              dont forget to pull the fuse on the fuel pump before jumping anything
              Dan
              • EtaSport
                • 2853
                Yea, I had one on my car when my ignition tumbler broke. Would go to on, but not to start. It was like 12 bucks. I've got pushbutton on my 49 chevy too. I didnt know you could jump those two posts on the plug. Is that just motronic 1.1 and greater? or can I do it on the eta too?
                Old and improved:
                • UNHCLL
                  • 8789
                  put it in 5th gear, pull the spark plugs and roll the fucker you sissy. or put a wrench on the crank nut you lazy mass-hole. :P ;)
                  Below the radar...
                  • rs4pro3
                    • 5808
                    It will work eta's & I's and most up to 95 I believe.
                    • Bimmerfanatik
                      • May 2004
                      • 5349
                      Sounds like a nice alternative, any ON's for the pins? Or can I just use something else?
                      Maybe a DQ, but why? I never did this on the valve adjustments I've done before...
                      Listen, pal, you and I are gonna take this to F1. :) I don't have the vast garage space for rolling the thing forward, as you can see in the pics of my garage. And I don't want to have to try and go back and forth between the crank and watching the cam to see where it is. Kind of a pain in the ass ;)
                      You'er making me do Hartge instead of Mtech1. Die.
                      • UNHCLL
                        • 8789
                        Poor Scotty... his arms are so short he cant reach the wrench on the crank while looking at the cam...
                        8)
                        Good, glad you decided not to do mtech 1. stupid wanker wanting to copy my fly style! ;)
                        Below the radar...
                        • Bimmerfanatik
                          • May 2004
                          • 5349
                          8)
                          It only took you how many years to get a friggin Mtech 1 kit? Damn man, I've barely had my car a year and was ready to buy one.
                          That's ok, Mtech 1 is playyyyed out like alpinas. Same with dscwarz. I'm goin Hartge. Go ahead and find me a Hartge kitted E30 in the US. Bet that'll be HAHD.
                          I do have freakishly small hands and arms. What can I say :)
                          • arsevader
                            • May 2005
                            • 1025
                            This doesn't matter, as the engine won't start without the ignition switch on anyways.
                            James
                            • Bimmerfanatik
                              • May 2004
                              • 5349
                              James
                              Thought so. Silly Dan :)
