87 325IS Rear "Pop off Window" Installation?
  • daspoop
    • 163
    I was wondering how to install a rear pop off window in an 87 325is? I have a new window but have no idea where to get the bolts or where they go. Any tips will be appreciated.
    Thanks in advance,
    -Jeff
    The bolts than attach the hinge at the forward edge of the window are accessed by removing the B pillar trim. Those for the rear latch/operator are under the plastic cover.
    • daspoop
      • 163
      Thanks
      • daspoop
        • 163
        I thought I had the bolts to go with it, but I don't. What kind of bolts do I need in order to install this?
          You'll be able to snarf the fasteners off the old window.
          • 87_black_325is
            • 92
            More specifically, since I also have a 87 325is, remove the coat hook up top, and a round plastic cover below to get at the screws through the trim. Rear fastener is one screw that is a part of the "pop off" mechanism, so have the window popped out to get to it.
            I had to use a piece of hose to thread the bolts back on this way though (piece of hose just large enough for the nut to fit snugly inside of), takes a deep socket to get at them and could not get them to thread any other way.
            87 (OO=[][]=OO) 325iS
            Originally posted by mkcman17
            My car is powered by hopes and dreams
