New to r3v... Hi!
  • autbot318i
    • Jan 2011
    • 48
    New to r3v... Hi!
    picked up a 1985 318i with 129k on the speed. Of course this forum helped once i picked it up to replace the VDO gears in the cluster to get it running again. and from the 2 weeks that I've owned the 318i..I have spent countless hours reasearching the IDLE issue it has...sigh*
    But regardless, I will slowly build it back to the point realiable. So here are a few pics since I had the day off.
    orderd the control arm, CAB, sway barlinks, tie rods from FCP Groton. I think for the price its built pretty tough. we'll see how long they last.
    between replacing the antenna, waiting for the shifter parts (z4), water pump , thermo, debating between SACH or Bilstein. I have a decent amount of project work ahead.
    so lets begin...
    New.
    Old
    I cut a tubing that was teh same size as the lollipop and another piece for the inner diameter to press out the old busing
    finding the right tube was the hard part...I had way too many
    first I weld the tube to the anvil to try hammering out the bushing...that didnt work too well
    between using the press to extract...I laid a flat piece in front of the bushing to press it in the carrier.
    that worked!
    forgot to mention...yes there is a marking on the carrier and I simply mimiced the positon of the bushing like the old.
    my kitchen fork for control arm removal
    the driver side 22mm nut was a pita...could get a socket in there so i used this..with a socket at the end to turn it into a decent Breaker bar.
    this was the passenger side.
    the E30 CAB is a lot more forgiving than the last E46 I installed.
    took me a few hours..but all in a days work.
    here are some pics of the ride.
    still need cleaning
    *1985 318i* STOCK
  • b*saint
    • 3794
    make sure you get an alignment asap and welcome to r3v
    Ma che cazzo state dicendo? :|
    • jaywood
      • Jul 2010
      • 4528
      What's wrong with your idle?
      Car looks nice!
      • autbot318i
        • Jan 2011
        • 48
        thanks!
        the idle is at 1000rpm ive been adjusting the icv when cold it auto revs between 800 - 1200rpm.
        when warm at 1000. if i set it any lower it bogs down to the (ALMOST) the point of stalling but it quickly revs back up the rpm to about 1200 and jumps around 800-1200
        i also get the fuel usage meter shooting all the way to 40mpg back down to 0 this is when the car is stationary.
        confused
        the car has new plugs, caps, cleaned airbox.
        *1985 318i* STOCK
          The first steps in fixing the idle problem would be to remove and clean the ICV and to have a smoke test run on the intake to find the intake leaks.
          • matias88e30
            • Dec 2009
            • 1110
            good luck with fcp groton! i bought a complete front set, control arms, tie rods, sway bar links etc, both control arm bushings are fuckd after a year!
            no more boosted m20, 91 318i...
            • txtorquemade
              • 1758
              Hate hearing that. I put a e46 kit on my 330i. But with poly bushings. Not OEM.
              sigpic 1987 325is
