Pulse generator
  • 416stroker
    • May 2008
    • 2448
    Pulse generator
    Any one know if the ring the pulse genterator reads off for the spedo and Odometer is the same on late modle cars and early?
    I have a 86 built 87 325is with a 3,73 and a bearing started making noise, so I swaped for a late model 90 3.73 it had a differnt pulse genterator. I changed it to the one my car came with but now I have no odometer it worked till I pulled the diff when I hooked it back up I have nothing. But my spedo still works?
    Unless the cluster gears gave out at the moment I test drove the car with the new diff?
    84 318I Delphin RIP
    87 325IS delphin 24v Sold
    89 325 Alpineweiss
    As far as I know, the sector ring in the differential is the same.
    Since the speedometer works, the sensor in the differential is working. Your problem lies in the odometer and is probably failed gears.
    • 416stroker
      • May 2008
      • 2448
      I guess its one thing after another Time to pull the cluster
      84 318I Delphin RIP
      89 325 Alpineweiss
      • Jean
        • 18228
        iirc the early and late model pulse generators have different plugs...fwiw
        • 416stroker
          • May 2008
          • 2448
          Ya they do I was wondering if I had to get the late model plug and replace my early
          84 318I Delphin RIP
          89 325 Alpineweiss
