Wiring Fog lights seperately (so they work with parking lts)
  • Sean
    • 5793
    I can almost bet this has been mentioned on the forums once already. I did find the article at bmwe30.net, but it was for Post 88 E30's, and I wasn't sure if the wiring was the same or not.
    My question is, how can I get my fogs wired so I can have them on whenever I want, so I don't have to have my regular lights on with them.
    If there's an article, can anyone point me to it? I tried searching the forums, but nothing obvious popped up.
    Thanks!
    - Sean Hayes
  • llll1l1ll
    • 782
    www.bmwe30.net then go to articles and tips, electrical, and it should be under there. if not electrical, try somewhere else
    Me: "I can't wait to redline my car!"
    Mark: "Didn't you just break a rocker arm?"
    Me: "Yeah, I don't think I've learned my lesson."
    Mark: "You never will."
    • kidrobot
      Nekomata
      • 712
      Wire em into your accessories plus a switch.
      Easiest wat, especially since you7r accessories are
      only on with engine on or key in positive.
      「 Terror from the Rising Sun 」
      • Ryan Stewart
        I Love Miatas
        • 8978
        yeah, just use the supply pin (pin30?) of the foglight relay and hook it to the ignition wire. then power will be supplied whenever the ignition is on.
        Im now E30less.
        • Inspar8r
          • 301
          He has an 87 325, i don't thin kany of those suggestions will work. I have a 87 325 as well, and they didn't work on my car.
          Go to the tech section on my website www.mmsport.s5.com to ge tthe full instructions. the 88 and 89s are wired differently than most cars.
          All the above suggestions were for 88-89 models.
          Nick
          87 325 5MT
          02 IS300 5MT
          • Super Eta
            • 1884
            Can you turn off the fogs after doing this?
            • C ///M
              • 1040
              Yes. The article Nick supplied makes the foglights controlled by the foglight button and parking lights. For example. As soon as your parking lights are on, you can have your fogs on or off by pushing the foglight button on your dash. Basically it gives you the kind of setup that E36's and newer cars have.
              332iS R.I.P.
              • Rob
                • 8166
                anyone happen to know offhand any differences with a 91 car?
                BEERTECH
                • Maluco
                  • Oct 2005
                  • 6572
                  I just used the procedure on bmwe30.net to run my fogs independently/with my parking lights by jumping the 87 and 30 pin on the fog relay. However, this is causing my fogs to stay on regardless of the fog switch being on or off. Can someone tell me what the deal is? I would still rather have the option of turning them on or off via the switch. Thanks
                  This is on a 90.
                  • Maluco
                    • Oct 2005
                    • 6572
                    I followed that procedure exactly and my fogs are staying on period. I can't turn the off with the switch. They are on even with the keys out?
                    This is on a 90.
                    • QUiKSR20
                      • Jul 2011
                      • 187
                      This is a super old post but the links are dead, Any links to run fog lights with parking lights still out there?
                      89 325is w/ Euro smileys, Would love to run city lights w/fogs before its super dark thanks.
                      DG.
                      13 328i F30 6MT Tuned
                      95 325i E36 5MT Vert
                      89 325is ( sold )
                      92 Sentra SE-R SR20DET
                      - DET Build Thread
                      • IRON-E
                        • 16548
                        Originally posted by anthonyabatangelo
                        Fog lights should only be on when there is fog! That's my opinion, Some states have laws regarding this
                        Noobie, you do not belong in this thread. Now GTFO! :hitler:
                        @IRON-E30 aka Edwin:D
                        • hyperE30
                          • Sep 2009
                          • 2202
                          Ohhh snap....
                          Here is this one..
                          HyperWerkz
                          89 mtech2, s50, AR Kit, borgwarner s362, e-85, 15psi... 592whp
                          " enjoy the show "
                          • 'e30love'
                            • 893
                            i have a 91 318is the pigtails are there to connect fogs but no dash button and relays what do i have to do in order to have fogs?
