Central locking issue
    Well the problem just occurred today, my car will not lock with any of the three locks, trunk, driver side, pass side. It will unlock fine though. All the doors will unlock via central locking. I turn the key to lock the doors and nothing happens. I've had this issue once before but it seemed to have fixed itself.
    This time it is not doing jack. It's my daily and I do not want to leave the car unlocked in a parking lot. Is this an electrical issue? I believe so because another odd issue is that when I open my door the damn radio shuts off and then turns back on when I close it. Very weird and it started not that long ago? Any help?
    John F. Kennedy
    Yup, I would unhook the door harness behind the rubber boot which sits against the body when you open the door. there is a break somewhere in the wire and/or your a one or couple of door pins are corroded. You'll have to replace both the male.female pins to correct this "properly." is stress properly. lol
    if there is no problem there; then I would check the central control locking unit behind the drivers speaker cover below the speaker held in by two Philips screws. swap it out to see if this resolves the problem.
      Thanks for the reply man, I will definitely check that out.
      John F. Kennedy
        Read up?
        ..but yeah, what Ceeker said
