Has anyone wired up an aftermarket fan to run on two speeds like the stock aux fan?
If you were to remove the resistor pack and wire it up to the aftermarket fan the same way as stock shouldn't it run the same way as the stock aux fan?
I have a 2360cfm Flexilite fan that I'm going to try and wire this way. With the lower temp 80/88 degree switch of course. The recommended fuse for the Flexilite fan is 20 amp so the the 30 amp high speed circuit will be more than enough.
