Worn valve seals will cause a vacuum leak symptom right?
  • b*saint
    • 3794
    I was thinking today about what kind of symptoms would worn valve seals cause?
    Ma che cazzo state dicendo? :|
    The main symptom will be an increase of oil in the intake. Coupled with worn guides that can result in a bit of blue smoke from the exhaust under a trailing throttle.
    • b*saint
      • 3794
      Ok then I can rule that out. I'm starting to lean towards my dme. I've replaced every gasket and hose on my car but it still has a rough idle and seeks when coming down to idle. But it looks like a vacuum leaks because when the engine warms up it doesn't seek as much. Yesterday at -2 it NEVER smoothened out even with 15 mins of 70 mph highway driving.
      I've replaced the ICV and temp sensor. I replaced the cam position sensor because the old one was throwing a light. I need someone to use a computer and check the system making sure the DME is reading the right engine temp.
